Hi!
I need to create this functionality in LUA Code on Virtual Devices:
Aim: To toggle commands each time that button is pressed.
Description: The Virtual Device button called “Cursor Left” needs to save Two Commands “Global Cache Executable : InfraRed Code 1” and “Global Cache Executable : InfraRed Code 2”.
Working: We need that each time we press the button “Cursor Left”,  “IR Code 1” is sent and the second time we press the button “IR Code 2” is sent, when we press it the third time “IR Code 1” is sent and so on.
At no instance “IR Code 1” and “IR Code 2” should be sent together. It should always execute Code 1 then Code 2 then Code 1 . . . . . only when the virtual device button is pressed.
The program would be saved on each button of the virtual device, virtual device in this case would be a remote comprising of different buttons and codes.
How RC6 Codes Work : RC6 each codes is used in alternating order. After the first code gets sent, the equipment is looking for the next code.
Best Regards,
Kunal Sabharwal
5 answers to this question
This is like a flip-flop, so you need one global variable that will change with every press of the button and if/then/else should do the trick. Something like this maybe:
If you need to send IR Code 1 always first with another session then you need other code which will check something to reset global variable "FlipFlop" to 0 after first session is finished, maybe check if device is turned off and then reset?
Edited by Sankotronic
    Hey Thanks for your prompt reply.
    Tried using the code that you have shared, Request you to provide a full code for the Button Named "Left", I couldn't get this to work properly with the hint provided.
    Code I tried is also mentioned below, request you to send your code for one button, rest of the 30 buttons I could then do myself.
    You could also enter the code directly in to the Remote Button in the Attachment "Imported Virtual Device" and share that with me.
    My HC2 Static IP is : 192.168.5.105
    Global Cache IP is: 192.168.5.81
    Port: 4998
    Room: Test Room
    Name: Multi Media Remote
    Device Label : Left
    Device ID: Button 11
    What I Tried to do:
    --------------LUA CODE Below--------------
    String to send
    tcp = Net.FTcpSocket("192.168.5.105", 8888)
    -- tcp:write("Example body")
    if fibaro:getGlobalValue("FlipFlop") == "0" then
      fibaro:setGlobal("FlipFlop", "sendir,2:1,1,38000,1,69,343,172,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,65,21,22,21,22,21,22,21,65,21,65,21,22,21,65,21,65,21,22,21,65,21,65,21,65,21,65,21,22,21,22,21,22,21,65,21,22,21,22,21,22,21,22,21,65,21,65,21,65,21,1673,343,86,21,37320x0D0x0A");
      -- here goes code to send IR CODE 1
    else
      fibaro:setGlobal("FlipFlop", "sendir,2:1,1,38000,1,69,343,172,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,65,21,22,21,22,21,22,21,65,21,65,21,22,21,65,21,65,21,65,21,65,21,65,21,65,21,65,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,65,21,65,21,65,21,1673,343,86,21,37320x0D0x0A");
      -- here goes code to send IR CODE 2
    -- pause time long enough that first code is received
    -- before second push of the button is allowed to send
    -- another IR code
    -- fibaro:sleep(time) This I dont think is required.
    Try above code. I didn't test it but I hope that you know how to use TCP socket. Don't forget to declare global variable "FlipFlop" or what ever name you choose in global variable panel before playing with this code. It won't work without that global variable.
    Hi!
    Thanks for sharing the code.
    But this is the result I get upon debugging.
    Predefined Variables in the Global Variables I had declared as FlipFlop with Values 0 and 1.
    IP Address of Virtual Device is 192.168.5.81
    TCP Port : 8888 and 4998 (Same Result Below)
    Button Label : Left
    Button ID : Button11
    The IR Emitter have no current in them, they are not sending any Signal.
    Where could the problem be???
    for the first function TRANSFER is Capital and for the second function FAILED is Capital "I changed that to understand what was happening".
    [DEBUG] 10:16:41: transfer FAILED
    [DEBUG] 10:28:57: transfer FAILED
    [DEBUG] 10:28:58: TRANSFER failed
    [DEBUG] 10:29:00: transfer FAILED
    [DEBUG] 10:29:01: TRANSFER failed
    [DEBUG] 10:29:02: transfer FAILED
    [DEBUG] 10:29:10: transfer FAILED
    [DEBUG] 10:29:13: TRANSFER failed
    [DEBUG] 10:29:16: transfer FAILED
    [DEBUG] 10:29:26: TRANSFER failed
    [DEBUG] 10:29:50: transfer FAILED
    [DEBUG] 10:29:54: TRANSFER failed
    [DEBUG] 10:29:55: transfer FAILED
    [DEBUG] 10:30:19: transfer FAILED
    Coud[DEBUG] 10:16:42: TRANSFER failed
    [DEBUG] 10:17:00: transfer FAILED
    [DEBUG] 10:17:01: TRANSFER failed
    [DEBUG] 10:17:03: transfer FAILED
    [DEBUG] 10:17:04: TRANSFER failed
    [DEBUG] 10:17:05: transfer FAILED
    [DEBUG] 10:17:05: TRANSFER failed
    [DEBUG] 10:21:45: transfer FAILED
    [DEBUG] 10:21:47: TRANSFER failed
    Well, I hope you didn't just copy and paste my code. Part with sending string command you have to check and correct! There is no way I can do that for you since I don't have IR Emitter that you mention to test. Hope you have some kind of documentation for it to check and correct string command.
