zwave.me WallCS template
I have old and new zwave.me WallCS units. In the old version a parameter template (nr 370) is attached to the module containing the most used parameters.
The new version lacks the template so you have to add all parameters by yourself. Not a big problem but the template is more convenient.
how can I attach a template to a module?
HC2 software 4.100
12 answers to this question
HC2 software 4.100
Can you send me a screen shot from your advanced settings of the device?
Do you mean that now all the devices do not have templates?
    see attached jpegs.
    In the new one I added the parameters at the bottom myself.
    Are you sure that this is the same device model?
    One is indeed decribed as Zwave.me, but another seems to be Popp & Co.
    it is sold to me as the same device, it has exactly the same layout and appearance. Every shop sells this item as the second version of the Zwave.me WallC-s.
    Yes I also noted the difference in Producer name but for the rest it is the same device.
    It accepts the same parameters, the user manual is the same (beside some details) it has the same properties (but one) etc.
    Please look also here
    Also here you can see the similarity but one property is missing.
    I have the same problem, but it is showing another property, which is not shown before: sceneActivationSet().
    No template has been found during the inclusion and the device is detected as Popp wall switch instead of the zme_wallc-2. The old wall switch has worked and had a template. The new one is not taking over the parameter update, but shows at the end a blinking red led, which indicates an error, may by the missing or different parameters. The switch is not sending any button information due to this issue and cannot be used until a fix is delivered.
    Edited by JeyDee
    and what is with the HTML file in the attachment?
    and is the fix for the HC2 software or for the Wallc-2 firmware?
    No, it is the report for Fibaro to create the missing template.
    apparently another company is producing the WallC-S now.
    The new version is produced by Popp and altough my supplier tells me it is the same device, that is only true for the mechanics, not for the electronics.
    1) there is no template available for the Popp version of the WallC-S
    2) the programming is completely different, see my other topic in this forum:
    If you have created a missing template for a device please send to at [email protected]. Remember to indicate what device it is - exact model, firmware version, etc.
    I have send it on 15th October to the named email address.
    I checked the inbox. Indeed, the file was received and forwarded to the appropriate team.
    Is the Wallc-s fully integrated to HC2 and HCL now ?
    Because I have big problems with Vera Plus and Wallc-S, so I'm thinking to switch for a HC2 /HCL.
    But if it's to meet the same issues ....
    Thanks for your reply
    Jerome13
