Amazon Echo Fibaro Integration - Quick Guide in FULL
Hi
after trawling through a few sites and you tube videos i managed to get Amazon Echo to work with HC2.
so i decided to write a small-ish tutorial to make life easier for anyone else that wants to do the same.
Download the instructions from
i have put the Raspberry Pi image file and a pdf of instructions there and it takes about 20-30mins and you are up and running.....
Video Below:
Thanks all and Enjoy!!!!
Guest spazpeker
Yes
here is the dim command for a VD slider
http://user:[email protected]/api/callAction?deviceID=439&name=setSlider&arg1=1&arg2=${intensity.percent}
8 hours ago, spazpeker said:
Yes
perfect @spazpeker.. Thanks
Guest spazpeker
I did do  VD to control sonos with it
I've started to look a creating a VD that allows a user to connect to Alex Voice Service and control the volume level and mute on the echo dot.
The api seems to enable this and I'm working on the authorization required and will then look at how to create a VD per echo dot
My use case is adjusting volume for night v day ( for alexa's OK) and being able to mute/silence alexa at appropriate times
Before I go any further has anybody else done this or is there a HA bridge capability that I'm not aware of that enables this ?
_f
Thanks for sharing @spazpeker
Edited by AutoFrank
This is the standard scene call
Start a Scene: http:// USER%40EMAIL.COM:PASSWORD@IPADDRESS /api/sceneControl?id=ID&action=start
Does anybody know how to make a scene api call and pass an arg with the scene call
thanks
_f
Found it
Edited by AutoFrank
Hi @AutoFrank
Have you looked at the Echo Dot API?  The Echo Dot has its own IP Address, and I wonder should you look at the API, whether you cannot control volume etc via a Fibaro VD or so?
This is not my field of expertise but logic tells me it might just be possible.
Could members with more technical skills, tell us whether the above is possible?
Thanks a stack
L
@morpheus75
1 minute ago, lennypenny said:
Hi @AutoFrank
Thanks a stack
L
@morpheus75
Thanks @lennypenny, I had a look at the api and the api authentication is complicated. I though that since BWS had this part resolved for control then the addition of speaker control may not be too much of a lift. I didnt think to see what was running locally, I assumed it was locked down but will check later
