[SOLVED]Fibaro motion sensors - Not possible to change default values
Oddgeir
Does anyone experience that it is impossible to change default values for the fibaro motion sensors in HC2.
What ever values I give and save is reverted back to the default values.
I want for example to change parameter 80 to 0-LED inactive as I am installing the sensor in the bedroom and I for sure do not want to have constant blinking!
I have also tried changing other parameters but no matter what changes I make they do not save. That is when I go back into the settings all values are back to default values.
Edited by Oddgeir
Guest FredrikKarlsson
Are you waking up the device after each update of a parameter value?
That needs to be done for updates to be stored in the device.
