device updates status after "poll this device"
Hi All,
I have a horstmann combination of a thermostat and a boiler switch connected to the CV.   Problem is this; when I switch on the thermostat, it switches the boiler switch nicely on.  But the status in the app(s) both web as IOS don't indicate the boiler switch is switched on.
After pushing the button "poll this device" in the web environment, the status is put right  (on or off, what I set on the thermostat).
The pulling interval is every 10 second.
Geavanceerd
Node ID:99
Parameters template:44
Z-Wave protocol type:6
Z-Wave protocol ver.:2.78
Polling tijdsinterval:.Het apparaat wordt gepolled  op periodieke Intervallen 10 Seconden
Geavanceerd
Anyone got an idea to get the polling really working? Can I do it with some LUA code? A script running every minute just polling the device. obviously it doesn't poll by itself.
Help ie appreciated!
On 29-11-2016 at 10:56 PM, barend121 said:
Tried this on the boiler switch and did not work. Did you reconfig the boiler switch or the thermostat?
I reconfigured the boiler switch.
