I've got the IDLock working normally for some time, then decided to install the Z-Wave module to integrate it to my HC2. The device is recognized, but there's no template, and limited functionality should be expected. However, the lock doesn't respond at all to any attempt to lock or unlock.
Any ideas?
And Hopefully Fibaro will provide a template for this module some time soon.
Thomas
On 10.11.2016 at 10:46 AM, thomassp said:
Hi
I have just sent the template to [email protected]. Hopefully you will get something useful out of it, and be able to enhance the usability with Fibaro to match that of HomeSeer.
thomassp,
There's a full manual detailing all the Z-wave commands. Did you include that as well?
Fibaro,
Have you been in touch with the ID-lock guys for a reference lock to test / implement template?
OleKenneth
    21 hours ago, olekenneth said:
    thomassp,
    Fibaro,
    OleKenneth
    Yes, @olekenneth, I included the full manual from ID-Lock as well as the template itself.
    Thomas
    thomassp,
    Linked devices for the video gate only support a limited set of Fibaro Z-wave devices as actuators for the lock. You cannot select the lock in this list. But you can select another relay as a "dummy" / replacement. I have several Fibaro 2XRelays and some of them only use the first, leaving med an unused 2nd relay, not connected. I set this relay in the video gate. I have a script (similar heading to the one quoted above) that is triggered by status change in this otherwise unused relay, and this script can include the doorlock unsecure command, among other things, of course.
    Maybe this was clearer, - or not...
    Thanks @olekenneth, this makes much more sense to me. I'm a beginner at this, so excuse the stupid questions :-)
    Thomas
    On 2.11.2016 at 9:11 AM, T.Konopka said:
    Adding a template is not an easy task. Moreover, it is very time-consuming and the device has to be in our hands in order to create a correct template. At the moment, we do not have ID Lock. However, we encourage users who possess devices without templates to help us. You can create a template and send it to [email protected] . This definitely facilitates adding templates and makes it quicker.
    Any update on the status of IDLock? Getting proper support for IDLock seems like it would go well with the latest beta.
    Any news on IDLock template? Or does anyone have the LUA code needed to send notifications?
    Any ideas?
    Thomas
    Hi Thomas.
    Whern you install the ID-Lock it is important to have the HC2 very Close to the Lock - less than 2 meters. You have to install it by choosing "Add Lock". After installing, and when HC2 still is Close - choose syncronisation (when you have added all PIN, RFID etc.. I recommend that you add one PIN, then syncronize and check the position this adding get in the table. Then add a few more, sync ... until you are finished.
    So - uninstall Your Zwave module following the manual - then add it again as described
