I have a new Aeon Multisensor which is failing to install. If it does it installs and shows not configured.
I have removed multiple times and re-installed. I have factory reset the device.
Does anyone have any suggestions, besides returning the device?
10 answers to this question
Guest chaicka
  • Is it the MultiSensor 6?
  • What is the firmware version of the MultiSensor 6 (check the box, there is a label that states it)?
I recently buy Aeotec (AEON Labs) Multi-sensor Gen 5 (not version 6) with firmware version 1.2 and it doesn't work as expected. Inclusion went smoothly but after inclusion there are no parameters at all. Also values were not updated except if I press button on multi-sensor. Pressing button "Pull this device" did nothing. After adding some parameters it start to update values but motion sensor is still not usable so I think that I still missing some parameters. Inclusion was done with batteries inserted, not with USB. Here are some screenshots :
Master and motion sensor are hidden:
Here is parameter template version, but when "Use template for parameters" is checked there are no parameters at all:
So I unchecked "Use template for parameters" and added some parameters:
but still motion sensor is not working, light sensor is totally crazy and if light is approximately above 200 lux it shows 1000 lux, temperature is measuring lower for 1-2'C and humidity is lower for 2-3% when compared with measurement from Netatmo weather station and/or Fibaro motion sensor.
I bought it because it has humidity sensor and it can be placed outside, but it is completely waste of money unless someone has some advice for me what to do to make it working better with HC2?
Edited by Sankotronic
Attachment quota filled up / deleting older stuff sorry :-(
i have the same problem - motion sensos didnt work :/
i have only one update of this sensor - 3days ago.
i know from other sources, that the same situatuion is with multisensor gen6.
Fibaro, why we doesnt have template for this devices?
How long we need to wait for this?
Guest chaicka
Aeon MultiSensor 6 has parameters template in HC2 since a few firmware versions ago. I have two of them and both are working fine now except the batteries only last max 3+ months instead of 1 year as mentioned in manufacturer's materials.
Template ID should be 755.
did anybody find find out how to get the Aeotec Multisensor Gen 5 to report movement?
I have a multi sensor 6 and that works fine but the older version doesn't report movement.  I'm assuming it's a parameter we need to set or some confirguration link. Anybody know the fix? I've got 4 of them and none report movement.
thsbks in advance for any help!
@CelticWebs this is how I did it. Good luck
Jim
Thanks Jim,
ill give those settings pictured in the post a whirl and see how I get on.
Celtic.
Seems to have worked perfectly using those settings :)
Now all I need to do is find the parameters for a Yale Keyless lock I bought that doesn't update it's status but does actually work!
Glad it worked!!
Sorry can't help you with the lock.
Jim
