msgasson 1
I can't seem to get scene activation on my dimmer module to work. I would like to activate a scene when a light switch is pressed x3. I'm using a momentary switch and have set parameter 28 to allow scene activation on the module. It works is I run the scene in HC2, but not if I click the momentary switch. Any suggestions? The aim is to activate a scene when I leave home.
Not sure how to copy the coding - but here is a copy.
%% autostart
%% properties
16 sceneActivation
%% events
%% globals
if (
( tonumber(fibaro:getValue(16, "sceneActivation")) == 15 )
or
then
fibaro:call(154, "turnOff");
12 answers to this question
