Hello
I have problem. I use Fibaro HC2 with 15pcs of philio pan06.
After power off, some of philio modules become "not configured" and by "Wake up", they do not come to z-wave network.
How can I solve this problem ?
What is problem for ?
Thank for who replies
8 answers to this question
i never used philio pan06, but having 15pcs (so not DOA problem for sure), and two gateways (HC2 and Vera) i would say the problem is on philio pan06 itself, probably the configuration of overload alarms or association. Please check if all parameters has been set properly
    Hi.
     there is no load on this and association Group1 is on HC2. I also added AG2 and 3 to hc2 but failed again !
    " to "
    Temat został przeniesiony z "
    " do "
    I solved it, you have to set the association groups 2and 3 to HC
    Hello dear Marshal
    Actually by doing your solution, just on/off feedback becomes faster.
    The problem is about after power cuts, then it will be dead and do not come back by clicking, wake up and poll !
    3 hours ago, [email protected] said:
    Hello dear Marshal
    Is this problem with your new HC version?
