Is VD or Scene better for this?
AutoFrank
HI,
Looking for some advice here
I have a simple scenario. Enter room, sensor picks up the movement, lamp turns on.
I can implement this as  a scene (clode below) but I seem to get a lot of "too many instances", presumable because the sensor gets triggered when we are in the room
I could also implement this as a VD in the main loop (code below)
In terms of best practice or least load on the HC2 or what do our guru's generally do ?
Frank
VD Lua
Scene Lua
12 answers to this question
Hi @AutoFrank,
Why are you triggering scene with global variable instead with motion sensor? Is there a particular reason? When and with what you are changing value of global variable G_SPC_ZONE_INPUT_18?
I'am asking this questions because I use scenes to control my lighting and they are not causing any TOO MANY INSTANCES warnings even they are triggered by motion & light sensors and even doors where required.
  • 10 hours ago, Sankotronic said:
    Hi @AutoFrank,
    Hi @Sankotronic
    input 18 represents one of my Siemens alarm sensors
    I use Goran's SPC Gateway and all my standard house sensors are mirrored in my HC2 as global variables
    Specifically G_SPC_ZONE_INPUT_18 is a PIR in the corner of my living room
    thx
    Hi @AutoFrank
    Now it is more clear to me what problem you are facing. Can you tell me one more thing. How this motion sensors are working? I mean, do they have blind time after registering first movement and keep breached state during that time and how long is that time?
    Or to be more clear when global variable for motion sensor state change to breached, for how long it will keep this state before is set back to safe? What values do you use for breached and safe state? Numerical or strings?
    I ask you all of this because I have scene that is working very good with battery motion sensors but I want to try to adapt it to be used with your system too so I need to know more details to be able to do that. Thanks!
  • 7 minutes ago, Sankotronic said:
    Hi @AutoFrank
    Good questions
    It's a wireless standard PIR (not zwave) and I don't think I have that degree of control over it's response but I see the point and will take a look
    I can see the state change ( using a VD I put together that reads the global variable) within 1-2 seconds of entering the room and it switches to 'safe'  pretty fast if I stop moving.
    Global values are 0 and 1
    For me the scene is working well using either a scene or a VD and I was just wondering which is a better overall approach
    thanks
    As I mentioned before I use scenes to control our lighting and it is working very good. I also incorporated this blind time to adjust for proper timing. I believe I can adapt this scenes to be triggered by global variables instead by sensors. Why I want that? Well, you can check here what are this scenes capable of if you didn't allready:
    So adding one more feature will make it even better. :-)
    Thanks .. looking forward to seeing the finished product
    Hi @AutoFrank
    This is debug window from Very Smart Light™ scene:
     Just tested scene when triggered by global variable and looks very good. It doesn't matter how frequently motion sensor is breached and how frequently global variable changes its value, scene is running only one instance. It is now ready to be posted.
    I have only one question. When I try to add global variable
     to my HC2 on 4.100 it was too long so system cutoff last number from name. How did you manage to add global with such long name? Did you do it with REST API?
    Edited by Sankotronic
    Attachment quota filled up / deleting older stuff sorry :-(
    just a question:
    in one of your scene is see this:
    meaning: in this way the history from the scene with be registered in the event tab from the HC2 ?
  • 16 minutes ago, Sankotronic said:
    Hi @AutoFrank
    I have Siemens alarm system and I purchased an SPC Gateway form Lundix IT
    When I installed it the variables were created for me automatically so I assume it was via the REST API
  • 6 minutes ago, samuel said:
    just a question:
    I have this function in all my scenes and use it to log specifc events/actions from a scene to a global variable called 'Log_Event'
    Since my HA solution is still very much a work in progress I use it to keep track of certain variable or activities so I can see if there is an issue. My log is different and separate from the HC2 log or events.
    I also have code to dump the log ( and clear it) when I enable morning mode but at the moment it's not working as the log is to big for the email. Training to find a solution to this ... I also have a scene where I can just view the contents of the log
    It's a bit rough but it works for me
    Log dump looks something like
    -frank
    " to "
    Temat został przeniesiony z "
    " do "
