Scenes stopped after alarm
Hello everyone,
Yesterday I played a little with the alarm panel. I armed and disarmed a few sensors and simulated an alarm. Unfortunately, I had to realize that this morning almost all the scenes were stopped.
Is there an elegant possibility to restart the scenes after an alarm without restarting the HC2 or saving the scenes again.
With more than 20 scenes that's a lot of work.
I know that you can prevent some scenes from stopping by setting the checkbox at "Do not allow alarm to stop scene while alarm is running", but sometimes this is not desired.
Edited by T.Konopka
Read descriptions of forums. You don't present any solution then why would you post in Crowd's Solutions?
" to "
Temat został przeniesiony z "
" do "
Hi @jwi and welcome to FIBARO forum!
Since you have HC2 it should be possible to write one scene that has marked "Do not allow alarm to stop..." and then that it checks if there was alarm breach, and after alarm is set back to safe, start scenes that were stopped. Since you have so many scenes that are running constantly I assume that you use block scenes and not LUA?
I started with publishing my solutions all in LUA, but still awaiting for forum administrators to approve. If you like you can follow me and maybe found some of my solutions good for your HA, because my solutions do not require any deeper knowledge of LUA, only to edit some well explained parameters. I have only one scene that is running all the time and is protected from stopping during alarm breach. Everything else is run only when necessary and I found that it is the best approach not to make HC start sweating and swearing.
My solution just get approved so please check here:
Edited by Sankotronic
