Showing results for tags 'alarm panel'.
HC2 Alarm panel: pre defined Panic Action dissapeared
johndeere posted a question in Scenes and Interface
Hi all, in the Panels menu, Fibaro alarm, advanced tab, pre-defined actions: the first pre-defined action "PANIC" dissapeared. I added and deleted some of my own scenes into other actions, and once the PANIC action is no longer there... Does anyone has any idea how to get it back? Thanks, Cheers!- 5 replies
- alarm panel
- panels
(and 4 more)
Hi Everyone, hope someone can help me out here. I want to run a scene when disarming the alarm (when it sounds) What I mean exactly is I do get the pop-up on the mobile app or web interface, I select "turn off", but then, I want to run a scene (to stop sounding the alarm through the sonons speakers for example) Is there some way how this can be done ? Greetings, Vincent
Hello I find lot of solutions on this forum with lua code but it's need HC2. I have only the HCL and I use the alarm panel to armed/disarmed the alarm. I would like to know if it's possible to activate automatically with a trigger the alarm ? thanks
- hcl
- alarm panel
Hi. Can I ask, do you have to enter a PIN to disarm a sensor? I have excluded the sensor from the alarm and set Alarm Panel to No in the configuration. HCL on 4.160. Fibaro Motion sensor, Door Sensor Sorry for the rooky question. Any help would be brilliant. Thank you.
Hi, does anyone know how I can "talk" to the alarm panel via LUA or via API ? I'd like to set the alarm via an imperiohome dashboard, have it working now without using the alarm panel but it would be nice to integrate. Greetings, Vincent
Hi , I am using both HC2 and HCL in master slave mode. and i tried to activate alarm panel to take actions in arm mode. first, i selected emergency lights , close blinds and send notification and tested it and it worked good. this situation was before adding any other scenes to the system. i activated the alarm panel in the HC2 (master controller) only . After adding several scenes ( Ex: scenes to open and close lights according to motion detection and LUX in several areas ) , i tried to re test the alarm panel by arming the motion sensors in my system and try to breach any of them. when i did so in the 1st trail only the blinds closed but no notifications sent and the emergency lights did not work as well. i tried to reset the alarm panel and deactivate all actions and re enable it again. when i did so nothing of actions took place. Hint : i have several scenes take place several rimes and always there is notification to alarm that that scenes run sequently more than the number of runs i set in each scene ( 10 times ) my question : is this delay due to these scenes which run a lot or this is a bug in system ? i am using the latest update in both controlled ( not the beta one )
- alarm panel
- master/slave
Hello everyone, Yesterday I played a little with the alarm panel. I armed and disarmed a few sensors and simulated an alarm. Unfortunately, I had to realize that this morning almost all the scenes were stopped. Is there an elegant possibility to restart the scenes after an alarm without restarting the HC2 or saving the scenes again. With more than 20 scenes that's a lot of work. I know that you can prevent some scenes from stopping by setting the checkbox at "Do not allow alarm to stop scene while alarm is running", but sometimes this is not desired. Thanks
On my alarm panel only 4 devices are shown. I have multiple door and window sensors installed. They all have the same settings. But only the sensors of 2 rooms are shown (the rooms that also have a motion sensor installed). How can I add the door sensors of the other rooms to the alarm panel?
Hello guys, is possible to have a solution for the bug 0003094 on the new version (beta / stable) ? This bug is from 2015-03 !!!!!! The search function in the alarm panel is terrible slow and the breached sensor in the log is not highlighted again!!!! Please solve it!!!!!!
