Questions about the push mobile phone app push
Hello, I'm hc2 can work normally, but I couldn't get a push notification from fibaro phone app, mobile phone has no closing software notification, push and no effect, I hc2 version is 4.09, and I come from China. Thanks
11 answers to this question
" to "
Temat został przeniesiony z "
" do "
你好 @fibarojiang,
command to send push notification is:
mobileID you can find by entering this link to your browser: http://<YOUR_HC_IP>/docs/#!/iosDevices/getIosDevices
To receive push notification your mobile phone must be sleeping otherwise it will not show. Also push notifications are deleted when Fibaro app is opened!
    15小时前,Sankotronic说:
    你好@fibarojiang
    发送推送通知的命令是:
    mobileID您可以通过输入此链接到浏览器发现:  HTTP:// <YOUR_HC_IP> /文档/#/ iosDevices / getIosDevices
    要接收推送通知,您的手机必须睡眠,否则它不会显示。此外,当Fibaro应用程序打开时,推送通知也会被删除!
    Would also like to ask, I then received less than fibaro of the country's mail is how it happened? Can you tell me if the new version needs to modify the administrator password?
    17 hours ago, Sankotronic said:
    你好@fibarojiang
    发送推送通知的命令是:
    My scene Lua is there a problem with editing? I follow the phone ID you said right, but did not push, the device is still in the advanced settings of the push does not work
    @fibarojiang, last version of firmware is asking to change admin account and use e-mail address. I have not upgrade yet so don't know details.
    I see that you use notification panel to send push. I don't use that option. I use LUA code to build notification text and then send. But I checked and this command should work:
    Is your HC2 connected to the internet? Do you have lit first 3 LED from the right on then HC2? Can you remotely connect to the HC2? Did you reboot HC2 and try to send push notification? I remember that firmware version 4.090 had problems with that.
    37 minutes ago, Sankotronic said:
    @fibarojiang,固件的最后一个版本是要求改变的管理员帐户,并使用电子邮件地址。我还没有升级,所以不知道细节。
    我看到你使用通知面板发送推送。我不使用该选项。我使用LUA代码构建通知文本,然后发送。但我检查,这个命令应该工作:
    您的HC2是否连接到互联网?你先点亮3个LED从右边然后HC2?你能远程连接到HC2吗?您是否重新启动HC2并尝试发送推送通知?我记得固件版本4.090有问题。
    My HC2 is connected to the Internet, I have updated to version 4.104, enter the host is the need to modify the administrator password, but I fill up my mailbox is correct, but did not receive fibaro mail. Our country's Internet is actually a LAN, it is difficult to connect with you, we need VPN
    22 hours ago, Sankotronic said:
    你好@fibarojiang
    发送推送通知的命令是:
    May I add your Facebook?
    I also have the same sort of issue, everyone in my house with an iPhone gets a push notification perfectly, but me and my Android are always left in the dark and never receive the notification :-(
    On 2017/1/12 at 1:15 AM, krisstoff said:
    我也有同样的问题,每个人在我家里的一个iPhone得到一个推送通知完美,但我和我的Android总是留在黑暗中,从来没有收到通知 :-(
    This should be the problem of Android system, IOS basic no problem
