Guest trappify
I'm trying to get associations to work between two FGD-212 modules.
S2 on Module1 should control Module2
According to docs Module2 should be configured in Association Group 4 and 5 of Module1. However I can't get it to work. Both modules are within 2 meters range.
One thing I noticed when configuring associations was that the ID that is displayed after "To be set" is not the same ID as Module2.
Should the "to be set" ID match the device ID of the module I want to control? Or is this some other ID?
Maybe my device database is screwed...Can anyone verify in their HC2 if the device ID should match the real device ID?
Please have a look at the attached screenshots, showing the "To be set" ID and the actual ID of the module I'm trying to control.
Andreas
Edited by trappify4 answers to this question
