Guest aj84
Hi all,
Unsure whether this one should be under HC2 or the modules so please move accordingly if needed.
This is one of a few threads going up today regarding the HC2 - like a lot of people here, I've invested a lot into the Fibaro brand with around 10-12 dimmer 2/relay modules, smoke, flood, handful of The Button, and then a whole load of other zwave bits for plugs and what not and on the whole, things are running very nicely but there are issues and issues that are now getting on my nerves.
Issue 1 is this thread:
Every so often, I find lights are on without requesting them to be on.
Checking the event panel for an incident this morning when I found the living room light on, I can see it was a fibaro controlled switch on rather than a physical switch.
The light turned on at 06:13:10 in a room that not only is rarely used but at 6 in the morning and 2 people in the house, there was no one awake to do it...so I switched it off.
This is not the first time this has happened however it has it's not happening as often so this is somewhat good news. There is no motion sensor linked to the above light and is a standalone dimmer 2 module with no scenes attached to it.
Other lights in other rooms have had similar issues but as mentioned, this has gone down randomly in the number of times it happens.
So what do you think?
