Guest aj84
Issue 3 of the day is a real bug-bear for me.
The fibaro mobile app is excellent for my requirements but it's not stable...always. I run this on an Samsung S7 edge currently on the beta 7.x firmware however this was the same on 6.x and I know on an older S4 I had the same issue with stock firmware.
Scenario:
App is open, working fine. I then switch networks whether its going from wifi to 4g (mobile/cellular) or changing wifi networks for instance when I go from my house into the car which has a hotspot.
When this happens, the app will do one of two things. Either it will crash out in which case when you re-launch, it opens and then closes and does this for about 10-15 times or it will disconnect and say it can't find fibaro.
I have to then kill the app or sometimes even reboot.
Why can't it run seamlessly between connections? I almost want it to ping the box constantly leaving a constant connection and if it can't find it, to keep trying until it does. I know I do not lose connection to a network for long - it will be a split second but this should not then cause this much issue.
The problem related to the above is for instance if I open the gates from the fibaro The Button from inside the house.
Get into the car, wireless hotspot fires up and mobile goes onto that automatically...but the app is already open (and sometimes it is closed too but then won't open for ages until it's happy with the connection - yet other apps work fine)
I then press close to the gates as I drive out...app then crashes out or disconnects.
I then have to wait 2-3 minutes sometimes to sort it out so I can close the gates at which point I give up and close them via the keyfob for the gate.
When this happens, the fibaro module then thinks the gates are still open so then I have to close them when I get a chance at work or when I am stationary...just really long winded.
