Guest aj84
This is more advice than a problem - I am considering getting two tablets for the house to put in the hallway to almost make a "startrek" type console in the wall.
Most likely 10" tablets with horizontal layout, I would then put the tablet fibaro app on there (unless I go for a generic z-wave apps available)
Is there an option to leave the app on always if the tablet remains on? Ideally I would probably want the tablets to dim to 1% for instance when not in use and then 100% once tapped but the app would still be connected regardless.
Anyone done a similar task? if so what is the verdict? what tablet did you use?
5 answers to this question
