RogierK 0
I'm having issues upgrading my HCL. I've upgraded before to 4.080 but now I cannot upgrade anymore. The system starts the upgrade, after a short while the status LEDs start 'walking' and keep doing that. I've tried multiple times now, even letting the HCL 'upgrade' overnight.
After the normal way failed I thought I'd try to upgrade using the recovery mode, but that isn't working either. The LEDs keep 'walking' when trying to boot in recovery mode. Network doesn't seem to be coming up. When connected to the router, no DHCP request is done. Trying to connect using a direct connection with IP 192.168.81.1 also doesn't work.
What are other option I have to upgrade the system? When the system reboots, it reboots normally and can be used. But upgrading doesn't work and the recovery console doesn't work either.
Thanks, Rogier
7 answers to this question
