Orgli 15
I operate a Axis M3027-PVE (180°).
It really works fine with different apps like TinyCam / IPcam Viewer / Synology or even just with a bowser (IR, Edge, Chrome, Safari).
HC2 (4.110) doesn't get the stream, although IP, mjpg & jpg links are correct (and can be opend in above mentioned apps/browsers.
The Plugin "Axis generic" finds the correct IP of the cam , but does not get the stream or still image.
It seems no problem of the right port.
Does anyone has an idea ? Including my Foscam and Apexis was no Problem
