Check when switch was last manually used
Hello!
Just started with LUA  and HC2 and have a question. I want to start with somethin really simple. When I enter a room and the motion sensor detects me I want the light to go on. When I leave and there is no movement for 60 minutes I want it to go off again. But if I use the wall switch manually to turn light off or on I want the automatic to be diabled for 12 hours (Dont want light to go on automatically in the guset room if someone sleeps there). I tried with fibaro:getModificationTime(<Id of my wall switch>,'value') but it changes value also when I turn ligts on/off programatically! How can I get the last time the switch was actually used manually?
Best regards, Mikael
7 answers to this question
" to "
Temat został przeniesiony z "
" do "
Try this script
I use it . With Babyroom I have switch with double toggle that controls a global sleepmode to Yes or No so the auto light wont go on.
    Ok thanks, but my question was not answered. I want to build something myself to learn how it works and I need a way to detect at what time a switch was manually turned on.
    A good way to learn is to take real examples and understand how they work by reading the code, make small modifications and see the results. Then you can do your own one needed.
    A bad way is to start programming without knowing what to do and how.
    Think I know what you're after as I looked for the same functionality when first using HC2. Short answer, not possible if the switch and light are on the same input/output pair. You will always get the last time the output was modified.
    To get what you are after from fibaro:getModificationTime() you need a switch wired to an input with nothing wired to the corresponding output and a device wired to an output with nothing on the input.
    Example using a Fibaro double relay:
    S1 = empty
    S2 = wall switch
    O1 = light
    O2 = empty
    Then a scene or association is the only way to control the light from the wall switch but it will effectively give you two device ID's. One for the wall switch and one for the light. Or use the double toggle as @D-Vine mentioned and keep track of the time in a global variable yourself.
    It would be a useful feature if there was a device parameter that "disconnects" the input/output pairs and when enabled would provide a different ID for the inputs & outputs for conditional control like this.
    I agree, not being able to tell the difference between a manual or automatic operation of a device is a problem.    To get around this, I use a global variable in the automatic operation scenes.  I update the global variable with the time when the an automatic operation occurs.  I can then subsequently interrogate the global variable in other scenes together with the GetModificationTime() functions to determine if it was a manual or automatic operation.
    Ok, tanks Siddler.
    This is a real pain as I always want manual switches to override all automatics. I can't understand how the system can't handle such a basic functionality!?
    I'll try to do as you suggested, but this means two global variables extra for each switch....
