Camara Hikvision DS-2CD2142FWD-IS
How do I add this model  Hikvision DS-2CD2142FWD-IS. There is only 2 model when look into Fibaro Device list.
I have a Fibaro Lite model.
Hi Salbaek,
I also have a Hikvision Camera  and I have added the camera via 'add device' --> To Add Camera.
In user name and password enter the username and password of you camera
In IP Address (including port if needed): enter the ipadres of your camera like: 192.168.1.7
In JPG path. If you choose a camera from the list, this field will be filled in automatically. Otherwise, please use URL address specified in device's owner's manual:
enter the following path:  /Streaming/channels/1/picture
In MJPG stream path. If you choose a camera from the list, this field will be filled in automatically. Otherwise, please use URL address specified in device's owner's manual: enter the following path: /Streaming/Channels/2
The urls can differ per type. You can find the complete list here:
PLEASE NOTE, The plugin in the browser doesn't work. You have to use the mobile version to test it. For me it works both on the Iphone and Ipad
Hope it helps,
Landshark
HikVISION DS-2CD2342WD-I  and DS-2CD2T42WD-I5  both of those cameras have substream that can be set to stream using MJPEC compression, so on theory they are compatible with HC2, right? Anyone that tested those?
DS-2CD2342WD-I
I bought yesterday this camera. Trying connect but without luck. With  Safari not working.
Edited by insippo
