Home centre 2 cant be found in Fibaro Finder
I just tried to restart my home centre2 from my computer. and it takes so much time. so i just powered the fibaro system manually and restarted it. Now i Cant my fibaro finder is not finding my Home centre2,
hope someone will help me soon
Thanks in Advance
    Can we connect our laptop directly with Fibaro HC2 through HDMI instead of connecting with Monitor/TV
    Vga cable socket under alloy cover beside network socket.
    I was having trouble connecting and plugged in vga monitor. On boot up it you could see the ip address it was trying to connect to.
    In my case I had changed routers and it was trying for some reason to connect to the old one with a different address.
    I guess if you got a vga to hdmi adaptor this would work.
    You must be able to borrow a computer monitor off someone close.
    Does a VGA to HDMI cable is enough or should we need a VGA to HDMI adaptor?
