Roller Shutter 2 - 3 Wire - No Switch
Hey Guys,
I have a roller shutter with no physical switch. It is controlled via RF.
It has a 3 wire power input - Live - N - Earth
Is there any way to control this roller blind using the Roller Shutter 2 module?
5 answers to this question
@MTressl you need to check with that manufacturer of the blind motor if they have a interface for 3rd party intergration.
I actually used a fibaro relay to operate a zero volt contact set on a blind interface , so you loose the fibaro roller shutter position indication.
Just checking your motor is wirelessly controlled?
you just have L N  E?
Edited by Jamie mccrostie
Guest fat
No you won't be able to control this as the FGRM will need to be able to send signals on the up and down direction wires which your motor does not have
But you may be able to buy a interface from the blind motor manufacturer that you can control with roller shutter 2.
I have installed these before.
6 hours ago, amurray85 said:
Hey Guys,
Can you hint us in the direction what you installed?
I am in a similar situation, where my GRIESSER motors only have 3 wires.
