mobbie 10
Hello All,
I have had my fibaro dimmer installed by and electrician and replaced the globes with dimmable leds (e27 type). I have also forced an auto config as I had changed the globes over.
When i dim the lights i only see change if I the slider is between approximately 100 and 40 and even if I go as low as 1 it is approxomately 20% less bright than 100%. Is there anyway to adjust this as I would like to make them very low during the night.
Thanks in advance.
Mobbie
4 answers to this question
