How to make a button in a VD what will restart your HC2 ?
Thanks for your help
-sbo
15 answers to this question
On 2/4/2017 at 11:15 AM, Sankotronic said:
@samuel,
works from scenes because I use it in my scene that monitors house power supply. I didn't try with VD but I expect that this functions should also work in VD.
just FYI
nevermind my post just do as Jompa writes - he knows what hes talking about i just stole my solution .P
Edited by Kuba13
beter way avalible
    would that be the plain username / password or do i have to convert my username / password by a method?
    Plain username and password
    It doesn't work: it returns in the log under the VD in the main page with "501"
    [DEBUG] 21:45:00: 501
    Does it need to be:
    HC2 = Net.FHttp("127.0.0.1", 11111) OR  HC2 = Net.FHttp("127.0.0.1")  ?? or with another tcp port number, or none ??
    My user name is a plain email adrdress, will that work?
    on top of the page, under general or advanced I filled in the following
    Room: Service
    IP = ""
    TCP port = 80
    in a buttom of a VD i fill in the following:
    fibaro:call(259, "sendDefinedPushNotification", "186");
    fibaro:log("Re-starting HC2...")
    fibaro:sleep(20*1000);
        HC2:setBasicAuthentication("user","password")
        response, status, errorCode = HC2:POST("/api/settings/reboot", "data=reset")
            if errorCode == 0 then
                fibaro:log(status)
            else
                fibaro:log("error")
    What I am doing wrong?
    Edited by samuel
    @samuel, @jompa68
    To reboot HC is it really necessary to use http? Can this be done with LUA function:
    I know that this function:
    Edited by Sankotronic
    Hi Everyone - since the new login method came out my VD stoped working? I ve change my login for email using %40 instead @ but still no luck :(
    Any idea how to do it now??
    That was the same for me, it didnt work wiith the %40 from the @ (email)
    Make a VD add in the button
    fibaro:startScene(SCENE_ID);
    SCENE_ID from scene put the SCENE_ID in the fibaro:startScene(SCENE_ID); fro the VD
    Make a lua scene and add this in your scene:
    %% properties
    %% events
    %% globals
    fibaro:debug("HC2 will reboor in 3 seconds")
    fibaro:sleep(3000)
    HomeCenter.SystemService.reboot()
    This worked for me.
    Thanx samuel i get u + for quick answer and it is working for me :)
    Any Idea how to do it for HClite?
    Apparently not because i don't own a hclite, but a HC2.. uhmm.. hclite aren't able to do lua coding, understand
    @confesor check the cookbook, there I have the scene for the HCL. Hope it works for you too.
    %% properties
    %% events
    %% globals
    fibaro:sleep(3000)
    This worked for me.
    hi,
    can you pls export this VD and send.
    I made the lua code as told but cant understand SCENE part?
    Can you pls tell me step wise or by photos how to do this.
    Add a scene called: "Reboot HC2". Copy / paste the following code in the scene:
    Save the scene and set it as manual.
    %% properties
    %% events
    %% globals
    fibaro:debug("HC2 will reboot in 3 seconds");
    fibaro:setGlobal("HC2", "RESTARTED");
    fibaro:sleep(3000);
    HomeCenter.SystemService.reboot();
    Add a virtual device (VD) and add a button called "Restart"
    copy / paste this in the button:
    local selfId         = fibaro:getSelfId();
    fibaro:startScene(308); -- start restart scene
    Change "308"to your Scene ID
    And when your press the button in your VD then after 20 seconds the HC2 will reboot
    Let me know how it goes :-)
    Thanks for the helpful answers above folks. Is there a way this can monitor an active network connection and if not it runs a scene to restart? I find when a data connection drops, often the hc2 will not pick it back up once the router is back in action.
