<solved> extracting data from JSON response
,maybe someone can help me with the following question:
the response i get from a HTTP request on my heating controller is :
 {"jsonrpc":"2.0","id":6538,"result":{"objects":[{"id":"211","properties":{"85":{"value":19.5}}}]}}
And i now need to extract  the value 19.5 out of this and put it into a variable.
at this moment I have the following data
   "jsonrpc":"2.0",
   "id":6538,
   "result":{
      "objects":[
            "id":"225",
            "properties":{
               "85":{
                  "value":19.8
and i can extract data up to the id= 225  with following code:
  local resultaat = json.decode(response)
  figaro:debug(resultaat.jsonrpc)
  fibaro:debug(resultaat.id)
  fibaro:debug(resultaat.result.objects[1].id)
  fibaro:debug(resultaat.result.objects[1].properties)
as soon as i put in the next level 85 i get a failure message so i'm really stuck
[ERROR] 19:05:58: line 16: ')' expected near '.85'
in reverse I would also like to put a value back into following statement:
{"jsonrpc":"2.0","id":11,"method":"write","params":{"objects":[{"id":"211","properties":{"85":{"value":"19.5"}}}]}}
so that i can write that to the device.
any help will be very much appreciated as i am just learning LUA and documentation is not very available/clear.
Edited 22 minutes ago by WimF
 0
Edited by WimF
9 answers to this question
    @petergebruers
    from Reading Your replies on other topics you migratie have the answer to my problem.
    I really would appreciate of you could have a look.
    17 minutes ago, WimF said:
    (...)  you migratie have the answer to my problem.
    Odd spell checker... I'll have a look!
    Can you please check if this helps? This is runnable code. The answers are in the code.
    Edited by petergebruers
    Or in that way
    @petergebruers
    @A.Socha
    thanks you very much for your responses.
    I will try this evening and let you know the outcome.
    @petergebruers
    This was working at the first go.
    Thanks you very much, I can no get the data from my heating controller and also be able to change it with a button in VD and write it back.
    The part that doesn't seem to be working is :
    for k,v in pairs(resultaat.result.objects[1].properties) do
      fibaro:debug("resultaat.result.objects[1].properties[\""..k.."\"].value:"..v.value)
    this would be a very nice option to have to read all the data from the whole house in one go.
    I do get following response if there are more values to collect:
    {"jsonrpc":"2.0","id":6,"result":{"objects":[{"id":"108","properties":{"85":{"value":129.0}}},{"id":"109","properties":{"85":{"value":"Keuken / Studie"}}},{"id":"148","properties":{"85":{"value":258.0}}},{"id":"149","properties":{"85":{"value":"Badkamer"}}},{"id":"188","properties":{"85":{"value":4.0}}},{"id":"189","properties":{"85":{"value":"Slaapkamer"}}},{"id":"228","properties":{"85":{"value":120.0}}},{"id":"229","properties":{"85":{"value":"Woonkamer"}}}]}}
    I can now spend the rest of my evening trying to understand what you did.
    thanks again.
    Edited by WimF
    2 hours ago, A.Socha said:
    Or in that way
    @A.Socha
    Thanks for your reply,
    retrieving the temperature works your way as well.
    Sending back data does not work since the changes need to not to be made in the response but in another string
    {"jsonrpc":"2.0","id":11,"method":"write","params":{"objects":[{"id":"211","properties":{"85":{"value":"19.5"}}}]}}.
    however its been helpful and it puts me on the right track.
    thanks you.
    @A.Socha
    Thanks for your help.
    this works fine after a small correction (typo)
    "jsonstring" and "string2" needs to be reversed in the final encoding
