Dimmer 2 connecting
Dear all,
I'm considering the purchase of a Fibaro Dimmer 2 to control 4 build-in LED spots. But actually I still have some questions about the installation.
For me, the Fibaro diagrams on their website are not that clear, so I will try to explain my set-up and questions.
I have 2 double toggle switches to control 4 build-in LED spots.
Pictures of both switches:
1st double switch: right switch to control the 4 spots
  • 2 brown wires on top
  • 1 black wire on top
  • 1 grey wire on top
  • 1 yellow/green wire on top
  • 1 grey wire at the bottom;
  • 1 black wire at the bottom
  • blue wire in the wall socket
2nd double switch: right switch to control the same 4 spots
  • 3 brown wires on top
  • blue wire in wall socket
  • brown wire in wall socket
  • yellow/green wire in wall socket
Can someone please explain if I need 1 or 2 Fibaro Dimmers to control the spots?
Can someone explain how I have to connect the dimmers? To which switch? Pictures would be great as I'm a real newbie in this matter.
Thanks in advance.
Kind regards,
Jonas
On 13. 2. 2017 at 9:13 PM, jonasm said:
Dear all,
Thanks in advance.
Kind regards,
Jonas
I am kinda conffused so:
you are controll 4 same LED (lamps/lights etc?),
what is total wattage of those LED lights,
are you planning on dimming them or can they just be switched?,
Each dimmer has 2 inputs (S1 and S2) and one output (Sx), if you are trying to controll 4 lights in unison one is enough, if you are trying to controll4 lights individually you need 4,
If you are newbie at electrics i highly recommand getting yourselve a quallified electrician whom will do this for the. It will save you quite a shock (depending on your locall standards it could be around 220V).
