Hi all,
I would like to limit the remote access to my HC2. Is that possible?
I would like to allow basic functionality like available in the app from outside the LAN. But I am uncomfortable allowing access to the scripting etc available from the webinterface. Is this possible? e.g. are these different ports?
Thanks. J
Probably not as easy on 4.110+ID.Fibaro login as it was back in the old days.
You can close ports 22 and 80,  slap firewall and DMZ between HC2 and internet... basically do everything you can outsside of HC settings .)
Aleternatively you can just go to settings and turn it off alltogether.
Not sure how limiting access is suposed to work under Fibaro ID to be honest. Maybe have separate ID account for non-admin users and only use admin for yourselve?
