Hi friends,
I am now working with Motion sensor and Relay.
I have used Block scenes to make scenes.
I made a scene to get the relay ON whenever the Motion sensor gets BREACHED.
Also I want the light to get OFF if there is no motion detected for 20s. For that I just edited my Relay's Parameter12 into 20s. Yet the Relay is not getting off even after 20 or more seconds.
Hope someone can help me soon
With Regards
Moosa Irshad
4 answers to this question
1 hour ago, moosairshad said:
Hi friends,
With Regards
Moosa Irshad
Assuming you are writing about FGS 223, than parameter 12 is related to second relay switch (Q2 output), meaning you need to turn parameter 15 on (value 1).
Edited by Kuba13
just because i can edit it, i do edit it.
    OH.. so how can I control ON time of Double Relay output Q1
    You should be fine just using proper settings of following parameters:
    10,
    11,
    12
    10(set to 1)
    11(set to annything i am guessing, 2 sounds usefull),
    12(set to your desired time).
    Just incase i am wrong i am including parameters with headers explaining what they do, so that you can insulate thyselve against me screwing up.
    thank you for your reply.. It works fine.
