mvrossum 0
Good evening,
I'm stuck trying to read the status of a device and use it on a local website.
(I want to have a tablet with a continuously refreshing page displaying the status of some devices.)
When i use this line in a browser:
i get the following json response from the HC2
ID=5 and properties.value=true
so device 5 is switched on.
If i save this in a text file as jsondata.txt and use the following example code i found on the net and modified:
i get the following response:
and that is exactly what i want, only i want it with the http api call.
so i changed the "$.getjson" line in:
But that does not give any response.
So the http request is correct, ( i get the right json response direct from the url in the browser)
and the script is correct, ( i get the right response using the textfile)
the php file and the jsondata.txt are on a webserver are and accessed from a laptop.
What am i missing ?
Mike.
