Hello all,
Has anyone tried to get the temperature data out from the home center 2 using the REST API because I am struggling. I can get other panel details such as the events etc which is using same format as the temperature but I get a parameter error. I have tried various things from such as with date settings and without with no success
In the developer guide (although seems incomplete) it has the following information in:
Temperature panel
URL: /api/panels/temperature
Methods: GET
Description: Returns Temperature panel data
Response: ?
Events panel
URL: /api/panels/event
IP/api/panels/event?from=xxx&to=yyy
IP – Home Center IP address
xxx – start date timestamp
yyy – end date timestamp
Methods: GET
Description: Returns events history from defined time, device states, state changes, their old and new values, etc.
Response: Gets an object containing events panel settings.
Please find attached images of what I am trying to explain.
Any ideas would be greatly appreciated.
Thank you in advance.
Trevor
Hi Trevor
Try using this API:
/temperature/{timestampFrom}/{timestampTo}/{dataSet}/{type}/temperature/{id}
Here's an example:
http://<HC IP Address>/api/temperature/now-36000/now/summary-graph/devices/temperature/135
The response is an array of values, eg:
[[1488009368000,18.40],[1488025027000,18.50],[1488025923000,18.40],[1488026818000,18.50],[1488027715000,18.60],[1488029508000,18.70],[1488031301000,18.80],[1488035783000,18.90],[1488036681000,18.80],[1488037576000,18.90],[1488039369000,19.00],[1488041163000,18.90],[1488043852000,19.00],[1488044748000,19.60],[1488045368000,19.60]]
Dave
