Brom 1
Hi Guys and Gals,
I am very new to Fibaro and looking to monitor my gogogate (
)I see it has IFTTT support but its only got open/close support. You cant actually monitor it.
I would love to create a virtual device that just shows the gogogate and the door status(s).
I contacted gogogate and they told me their API was closed and wont give me any documentation. So I had a quick look at their source code and it seems simple enough...
It seems trivial to get the status from the unit.
http://IP ADDRESS/isg/statusDoor.php?numdoor=1
The unit responds with "FAIL" when the door is closed and "OK" when its open.
It seems to be raw text (not html)
But...
It also needs you to login first. I haven't been able to figure this bit out yet. (If I login first the commands above work)
The unit supports 3 doors (just change the number at the end)
Wondering if anyone has one of these and has done any work to integrate it?
I'm really happy with my gogogate as its a good all in one box that manages 3 garage door / gates with sensors etc. All it needs is integration with Fibaro and it would seem to be a perfect solution.
ps If anyone is interested and has one of these. Here are the functions from the unit.
http://IP ADDRESSS/isg/js/functions.js?v=2.25
This command seems to open and close the door
http://IP ADDRESSS/isg/opendoor.php?numdoor=x
Brom
