Showing results for tags 'garage door'.
Is anyone have experience with setting up garage door device built on smart implant + hc3? Currently it works perfect in my setup but looks like simple light switch, so i looking for any suggestions to turn it to garage door.
- 6 replies
- hc3
- garage door
Hi Guys and Gals, I am very new to Fibaro and looking to monitor my gogogate (https://www.gogogate.com/) I see it has IFTTT support but its only got open/close support. You cant actually monitor it. I would love to create a virtual device that just shows the gogogate and the door status(s). I contacted gogogate and they told me their API was closed and wont give me any documentation. So I had a quick look at their source code and it seems simple enough... It seems trivial to get the status from the unit. http://IP ADDRESS/isg/statusDoor.php?numdoor=1 The unit responds with "FAIL" when the door is closed and "OK" when its open. It seems to be raw text (not html) But... It also needs you to login first. I haven't been able to figure this bit out yet. (If I login first the commands above work) The unit supports 3 doors (just change the number at the end) Wondering if anyone has one of these and has done any work to integrate it? I'm really happy with my gogogate as its a good all in one box that manages 3 garage door / gates with sensors etc. All it needs is integration with Fibaro and it would seem to be a perfect solution. ps If anyone is interested and has one of these. Here are the functions from the unit. http://IP ADDRESSS/isg/js/functions.js?v=2.25 This command seems to open and close the door http://IP ADDRESSS/isg/opendoor.php?numdoor=x Brom
G'day All, Just giving you a heads-up regarding a defect in the LUA code generator for the Aeotec Garage Door Controller. Specifically, when there is a timeout applied to the trigger. if (( fibaro:getValue(72, "state") == "Open")) then setTimeout(function() local delayedCheck0 = false; local tempDeviceState0, deviceLastModification0 = fibaro:get(72, "value"); if (( fibaro:getValue(72, "state") == "Open") and (os.time() - deviceLastModification0) >= 900) then delayedCheck0 = true; end The "value" parameter should be "state". The controller doesn't have a base property called "value" so the fibaro:get() function returns nulls. After that the whole scene falls over. Cheers
Hello, I love the new widget slide in the iOS. As I have found out, it only is for scenes not devices. I have a garage door opener device I really like to control with the widget. This way I can quickly open the garage door without even unlocking my phone. Any Ideas how to build this scene? Should be easy, the garage control is only a on/off relay switch. But all scenes seems to need a trigger? How would the magic scene look like? Tried with only Garage door == ON THEN but didn't work.. I want to trigger the scene myself, but the magic scene needs a trigger How to solve ? Please help, should be a quick fix for most of you skilled people Regards, Thomas
- 2 replies
- garage door
- widget
Roller Shutter connection to garage door motor
OLIVARE posted a question in Other Devices / Third-party devices
Hi Guys, Wondering if someone could help me figure this out please. I want to connect a garage door motor to a fibaro roller shutter, i have the following connections on the actual motor please see attached (connections from 1-10 ) Anyone know how to go on about connecting this to a fibaro module? Any help would be greatly appreciated! Thanks Kyle -
Hi All, Has anyone got any recommendation for connecting a garage door to Fibaro please? The type of opener I have is the standard Avanti brand that normally opens and closes with using a wireless hand held FOB open/close. What I would like is for Fibaro to detect that I am 1km away or entering geo fence - whatever the trigger is most reliable and the garage door opens. To close will be simply a momentary switch on the wall inside the garage. I would also like to open and close the garage door from anywhere on my mobile phone since I have web cams to detect who is at the front door and another inside the garage. This will be so delivery guys arriving at home while I am away, can make deliveries as I watch them via cam. Any recommendation please?
