I've got a Fibaro D/W sensor to which I attached an external temperature sensor Dallas DS18B20 - temperature is changing accordingly - from 12 C to 127 C
The sensor gives me a temperature that's higher than expected and it  is  correctly connected.
It's seems that figures are OK when i change decimal point - is it possible?
The temperature hold decimals - there should be a comma  after the first digit - it's not 52 C but 5,2 C
Can I make a VD with proper value ?
Edited by Kamol_
" to "
Temat został przeniesiony z "
" do "
Maybe dumb question, but did you tried soft-reconfiguration on that device?
Try to change Offset settings, parameter 53. Default value should be 0 (0°C)
