The manual for FGS-223 (combined manual for FGS-213/FGS-223) indicates that either can be used with 3-way switch arrangements.  It isn't clear to me how this can work with the FGS-223.  Can anyone explain how to do it?
    Thanks for the reply, but my question was about how one uses an FGS-223 in an existing 3-way arrangement.  I don't see the FGS-223 in your schematic.
    See thats where you have to be a bit careful. If you look at the two drawings they are quite different,
    but both will work depending on your exsisting wiring.
    If you are not sure you need a electrician to confirm this.
    We cant tell.....
    ie sometimes light load wire is connected in remote switch box and doesnt return back to first switch connections.
    also remember you need to change parameter 20 in the switch settings to 'toggle switch'selection
    Edited by Jamie mccrostie
