Why does this line in my VD not work?
This line here...
gives the error "line getGlobal ("Nursery_S..."]:10""
Yet if I debug the values for those two lines I get correct figures
fibaro:debug(volume) = 15
fibaro:debug(jsonTable.volume) = 30
It's just a button to reduce the volume on my Sonos from the current volume (jsonTable.volume) until it reaches a preset volume (volume).
It's a simple "greater than" comparison but I just get this error all the time.
17 answers to this question
" to "
Temat został przeniesiony z "
" do "
Hi @Desmo,
That error line that you copy/pasted, is it complete because it seem like is missing part. Anyway it doesn't seems to be related to that line of code with volume check. Sometimes debugger gives wrong code line for shown error so check the rest of the code or at least try to copy/paste complete error line and even at least part of code that it refers to.
    Yep, that's the complete line of code. Like you say, it doesn't really make any sense so I'll check the rest of the code.
    This is the entire code below. It controls my Sonos speaker and slowly fades the volume to the set amount, pauses playback and then returns volume to a preset state.
    It seems to be the "Fade Volume" section that isn't working as the volume keeps going down to zero rather than stopping at the required volume
    IP Address and Port have only been removed for security, they're all fine in the actual script.
    @AutoFrank...I know you're very familiar with the Sonos setup....any ideas what might be wrong here? I'm sure all the Sonos stuff is working fine as the correct volume is being reported in the debug lines.
    Edited by Desmo
    Just try first with changing first line of code to:
    because function fibaro:getGlobal is always returning string value (even it contains number) while table can contain number value so it is possible that you are comparing string with numeric value.
    Hi @Desmo
    The code has a slight error, you're not updating the reference volume (current volume of player) to check against and as a result jsonTable.volume is always greater than volume and it iterates down to zero and actually continues to loop
    you'll need to read back the new (reduced) volume and compare that against your target volume
    I can't fix your code sample as I don't know all the variables in play but the following is working example that should show you how such a loop should work
    -f
    drop it into ZeroBraine or a blank scene and you'll see the results
    I think I had tried that before but did it again and that first line then showed the same error....
    [ERROR] 13:33:03: line getGlobal (..."]:1
    I have called the new reduced volume back in to the loop, lines 6 & 7...
    What I have noticed (and changed in the code above) is that if I use a figure instead of calling the global variable the code works perfectly.
    It's just calling that variable that's causing a problem. I might try deleting the variable and starting again....could it be corrupt in any way?
    Hi @Desmo
    It sounds like a data type compare issue left
    @Sankotronic solution should work
    Could you drop this in and share whats in the debug window ?
    Same thing again...
    [ERROR] 14:44:06: line getGlobal ("Nursery_S..."]:11
    I even created a new global variable but have the same results.
    I could manually put the value in to the VD but I wanted it to be easily variable using a slider....this is just plain odd.
    14 minutes ago, Desmo said:
    Same thing again...
    @Desmo
    Thats a very odd error
    Could you screenshot the whole debug window ?
    I've added some text to the debug lines so they make sense...
    Ok, I didn't pay attention what function you use to get value from global variable. it is still problem with number & string comparison, but if you want to convert value from global variable to number then you must use fibaro:getGlobalValue instead of fibaro:getGlobal because former one is returning two values, value of the global variable and also time of the last change.
    So this is correct syntax:
    and the it will work.
    Thanks @Sankotronic, I will give that a go later on and report back.
    @Desmo
    I missed that .. sorry :oops:
    If you are still having issues let me know and I can try and replicate on my setup at home
    Thanks for chipping in @AutoFrank and @Sankotronic....that last fix has worked a treat :-D
    @Desmo
    glad it all worked out ;-)
    Edited by AutoFrank
    Great!
    Happy that it works! :)
