Hi Everyone,
What started out as a basic device monitor is now evolving into a family of offerings. As of today I am releasing a second offering (WWWAPI Monitor) and will be releasing a third offering in the coming week. As of today the family of monitors are as follows
1) WWWAPI Monitor {v1.0} - New (Mar8th) - vd that monitors only availability of the internet with option for sonos-api device.
2) Network Device Monitor VD {v2.5 } - vd that can monitor several + devices and has built-in alert notification options (pushover/pc2popup/hc2email/allinone)
.... and coming soon
3) Network Device Monitor for SMsgH {v1.0} - monitor designed to be used with the recently released
 {v1.0}
Regards
[Autofrank]
WWWAPI Device Monitor {v1.0} - Released March 8th
This has been designed as a Plug and Play version of the LAN Monitor VD. This new virtual device will just monitor the internet and can also monitor the device (raspberry pi, arduino, omega, etc) that is hosting sonos-api if desired. This version does not have any in-built notification options like the LAN Monitor VD 2.5. It has been designed to leverage the full range of notification and re-routing capability the
 {v1.0}
This simplified monitor is designed for users that haven't or don't want to adopt the full LAN monitor but want to be able to leverage the notification queue capability of this Smart Message Hub scene
/monthly_2017_03/58bfd6409780e_wwwapimonitor.PNG.d4eafa4d88b359cb5b384a885c2e4475.PNG" />
INSTALLATION & CONFIGURATION
Import the VD and globals will be created automatcally when the VD is saved
The default table in the virtual device is as follows
The virtual; device has already been set up to monitor the Internet (www.google.com)
If you wish to monitor a device hosting the sonos-api then modify the ip address to your setup (if you don't wish to monitor the sonos-api you can remove that entry from the table below and also remove the virtual device label that is displaying its status
If you wish to have offline/online status alerts set the alert = 1 for the respective device
There are just two configuration options
Set to true of you wish the alerts to be sent via the Smart Message Hub
When you run the scene first or if you modify the table in the scene you will need to set this to true
** SET BACK TO FALSE ONCE COMPLETE TO RUN THE VD IN NORMAL MODE**
and that's it
AutoFrank
FILES
Virtual Device ------------------------------>
Edited by AutoFrank
6 answers to this question
Very easy to setup!
The Sonos-API monitoring is cool!
Many thanks for sharing it.
    1 hour ago, Hoggle said:
    Very easy to setup!
    Thanks @Hoggle
    Glad you like it....
    thanks for this VD. IT works :)
    Can you help?!
    Edited by RubberDuck
    Can you help?!
    Thanks @RubberDuck
    Hi @AutoFrank ,
    Could you please move this topic to the Downloads? ;)
    Hello @AutoFrank,
    With update 4.590, the VD tell me that the system is offline, when it's obviously not.
    Can you help me identify the issue?
