I am using an httpclient request to get an address out of json array of google maps. It is working perfect but I would like to have the value out of the request scope/block.
I get a value at 1 but I do not get a value at 2. I hope someone can help me. Thank you!
longitude    = 52.568197
latitude    = 4.560753
        http = net. HTTPClient ()
        http : request ( 'https://maps.googleapis.com/maps/api/geocode/json?latlng=' .. longitude ..',' .. latitude .. '&sensor=false',
            options =  { method =  "POST" },
              success =     function (result)
                          output = json.decode(result.data);
                          address = (output.results[1].formatted_address);
                         print("1:" .. address)
                          end,
            error   =  function (err) fibaro: debug ("Errortje:"  .. err); end
print ("2: " .. address
13 answers to this question
latitude    = 4.560753
                          end,
Hi @mdejager
The issue here is that a scene with a http request doesn't execute as you would think.
It issues the http request and then moves onto and executes the rest of the code and doesn't wait for success or fail of the http request
This means that time it executes the print(2..address) it hasn't completed the request and assigned the address to the variable
The way I would solve this is to break it into functions and then use the setTimeout to delay the execution of the print(2..address)
The following code is runable
with output as follows
hope this helps
-f
    Cool thanks. I am going to try this
    i searched for synnchron/asynchron yesterday. Is there also a solution that the request waits?
    @mdejager
    No worries
    I don't know of any sync/async with fibaro
    Let me know how you get on
    Hi @mdejager
    The HTTP request will be processed asynchronously, and so as AutoFrank has pointed out, the only way to do what you want is to handle the address returned in the success function.  This is called after the HTTP request has completed as a callback function.  However, you could write the success function slightly differently so that all of the success code is moved out of the getAddress function, and this gets a little nearer to what I think you are trying to achieve, eg:
    11 hours ago, Dave Harrison said:
    Hi @mdejager
    Thanks @Dave Harrison
    I really like the compactness of the error and success handling and might borrow that in future :-)
    Thanks!. I will try this.
    Is there also a wait /await function for the http request?
    No, but Virtual Devices have a different http interface, and that one is blocking. It's probably easier to work with.
    On 12-3-2017 at 10:49 PM, Dave Harrison said:
    Hi @mdejager
    Thanks, It works perfect.
    Do i have to close this connection ?
    I've never seen an explicit close.  So, no, I believe the system closes the connection for you.
    Ok thanks!
    And do you know how to pass  longitude and latitude (or another var) from getAddress to processAddress? I cant get it to work on the normal function way.
    No, it doesn't work like that because the success function is a callback function and so the returned data is predetermined by the callback, and as far as I know this can't be changed.
    In processAddress, you still have available the variables which have been defined outside the functions at the top of the scene, so you could do something like this:
    However, due to the asynchronous nature of the HTTP calls, if you're processing multiple requests, then this won't work.  Take the following example:
    Then you get:
    The first address shows the requested latitude and longitude from the second address.
    You're best off using the location returned by the HTTP request, if you can.
    Dave
    I fixed it like this. Seems to work.
                                ProcessAddress(result,var2)
                                end,
            error    =    ProcessError
    Hi @mdejager
                                end,
    Nice one!  Well done for figuring that one out.  It works well.
    Dave
