jamietang 4
I have a scene where I set the motion sensor to turn on the lights when it is breached and turn off after 10 mins if there's no motion.
However, I face a problem that, whenever I try to turn off the lights manually, no matter with the switch or using the app, the motion sensor will be trigger and turn on the lights again. I'm sure it's not my movement that trigger the sensor as I've tried to turn off it outside of the room using the app, yet the motion sensor is still breach and turn on the lights again.
Anyone faced this issue before? Any solution for that?
Thanks!
15 answers to this question
