hi,
I send a weekly diagnostics report.  but I found out that the sendmail has a maximum number of characters .. about 832.
1) is there any other way to send out an email
2) Can I send html email with fibaro?
Regards
Martijn
4 minutes ago, mdejager said:
hi,
Regards
Martijn
Hi @mdejager
Unfortunately there is only one email mechanism
You could split it up into a number of messages and send one by one
You could also try one of the other notification services such as pushover or telegram but I haven't tested the limits with those services
    seems to be the only solution ..
    Do you know how the table of cpu should be interpreted?
    @mdejager
    Unfortunately I don't ..:-/
    I did look at it briefly a while back but reckoned that because it changes so much the memory and storage would be more useful to me
    I would be interested in the you code to generate the various reports if you'd be willing to share ?
    -f
    No problem. Here it is.. It is now runnning in a VD but I am thinking about moving it to a scene
    I still have to clean up a little.
    it takes the labels from from memory VD. you need that code too?
    ---    UPDATE MEMORY VARIABLES
        fibaro:call(fibaro:getSelfId(), "pressButton", "8")
    ---    MAKE CONNECTION
        connection = Net.FHttp("127.0.0.1", 11111);
    ---    FUNCTION REQUEST DEVICES
        getData = function()
          ---    MAKE CONNECTION
            response ,status, errorCode = connection:GET( "/api/devices/" );
          ---    STATUS NOTIFICATIONS
            fibaro:debug("status = " .. status);
            fibaro:debug("errorCode = " .. errorCode);
          ---    IF SUCCES
            if (tonumber(status) == 200) then
            --- DECODE TO LUA TABLE
                deviceTable = json.decode(response);
        return deviceTable;
    ---    FUNCTION REQUEST CONSUMPTION
        getConsumption = function(url)
        --- MAKE CONNECTION
              response ,status, errorCode = connection:GET( url );
         --- IF SUCCES
                 consumptionTable = json.decode(response);
        return consumptionTable;
    ---    CONSTRUCT SUBSTRACTION DAYS START DATE OF LAST WEEK
        if(os.date("%a") == "Mon") then      substract = 7
        elseif(os.date("%a") == "Tue") then substract = 8
        elseif(os.date("%a") == "Wed") then substract = 9
        elseif(os.date("%a") == "Thu") then substract = 10
        elseif(os.date("%a") == "Fri") then substract = 11
        elseif(os.date("%a") == "Sat") then substract = 12
        elseif(os.date("%a") == "Sun") then substract = 13 end
    --- SET VARIABLES
        UserId             = 2;
        lowBat             = 85;
        SelfId             = fibaro:getSelfId()
        dev                = getData();
        lowBattDevices    = "";
        deadDevices        = "";
        totalConsumption= 0 ;
        heavyConsumption= "";
        now                = os.date("*t")
        week_start        = os.time({year=now.year,month=now.month,day=now.day-substract,hour=0,min=0,sec=0}) --,
        week_end        = week_start + 604799 -- plus a week
    ---    LOOP THROUGH DEVICES
        for i = 1, #dev do
        --- SET VARS
              batLevel    = tonumber(dev.properties.batteryLevel);
             deadValue    = dev.properties.dead;
            deviceName    = tostring(dev.name);
            prestr         = "[" .. dev.id .. "] ➜ " .. deviceName;
        --- DEAD DEVICES
            if(dev.visible == true and deadValue == "true") then
            --- TRY TO WAKE
                fibaro:wakeUpDeadDevice(dev.id)
                fibaro:sleep(2*1000);
            ---    CHECK IF STILL DEAD
                if(fibaro:getValue(dev.id, 'dead') ~= "1") then
                       deadDevices = deadDevices .. prestr .. " ✔ Woke up \n";
                else
                    deadDevices = deadDevices .. prestr .. "❌ Did not wake up \n";
        --- LOW BATT / IF FIELD EXISTS
              if (dev.visible == true and (dev.properties.batteryLevel ~= nil)) then
            --- ONLY LOW BAT OF ALLREADYDEAD
                  if(deadValue == "true" or batLevel <= lowBat or (deadValue ~= "true" and batLevel == 255)) then
                    -- lowBattDevices = lowBattDevices .. prestr .. " - " .. string.format('<%s style="color:%s;">%s</%s>', "span", "red", dev.properties.batteryLevel .. " %", "span") .. "<br>\n"
                      lowBattDevices = lowBattDevices .. prestr .. " - " ..  dev.properties.batteryLevel .. "% ❌ \n"
                 else
                      lowBattDevices = lowBattDevices .. prestr .. " - " .. dev.properties.batteryLevel .. "% ✔ \n"
        --- CONSUMPTION
              if (dev.visible == true) then
            --- SET VARS
                url         = "/api/energy/" .. week_start .."/" .. week_end .. "/compare/devices/power/" .. dev.id
                Consumption = getConsumption(url);
             ---    ONLY IF THERE IS A KWH FIELD
                  if(Consumption[1].kWh ~= nil)  then
                 --- SET VARS
                      kwh = tonumber(Consumption[1].kWh)
                  --- HEAVY USERS LOOP
                      if kwh > 1 then
                            heavyConsumption = heavyConsumption .. prestr .. " - " .. Consumption[1].kWh  .. " kWh \r";
                  ---    TOTAL CONSUMPTION SUM
                      totalConsumption = tonumber(totalConsumption) + kwh
    --- CONSTRUCT MAIL HOME REPORT
        emailContent = "Weekly Home Report \n";
        emailContent = emailContent .. "Date: " ..  os.date("%d %b %Y - %H:%M") .. "\n \n";
        emailContent = emailContent .. "➡ Low Battery ⬅\r";
        emailContent = emailContent .. lowBattDevices .. "\r \r";
        emailContent = emailContent .. "➡ Dead Nodes ⬅\n";
        emailContent = emailContent .. deadDevices .. "\n \n";
    ---    SEND MAIL
        fibaro:call(UserId,"sendEmail", "Weekly Home Report " .. os.date("%d %b %Y - %H:%M"),emailContent);
    --- CONSTRUCT MAIL CONSUMPTION REPORT
        emailContentConsumption = "Weekly Consumption Report \n";
        emailContentConsumption = emailContentConsumption .. "Date: " ..  os.date("%d %b %Y - %H:%M") .. "\n \n";
        emailContentConsumption = emailContentConsumption .. "➡ Consumption ⬅\n";
        emailContentConsumption = emailContentConsumption .. "From: " ..  os.date("%d %b %Y",week_start) .. " till " .. os.date("%d %b %Y",week_end) .. "\n \n";
        emailContentConsumption = emailContentConsumption .. "Heavy consumption \n";
        emailContentConsumption = emailContentConsumption .. heavyConsumption .. "\n\n";
        emailContentConsumption = emailContentConsumption .. "Consumption total\n";
        emailContentConsumption = emailContentConsumption .. totalConsumption .. " kWh \n\n";
    ---    SEND MAIL
        fibaro:call(UserId,"sendEmail", "Weekly Consumption Report " .. os.date("%d %b %Y - %H:%M"),emailContentConsumption);
        emailContentMemory = "Weekly Memory Report \n";
        emailContentMemory = emailContentMemory .. "Date: " ..  os.date("%d %b %Y - %H:%M") .. "\n \n";
        emailContentMemory = emailContentMemory .. "➡ Memory ⬅\n\n";
        emailContentMemory = emailContentMemory .. "➜ Free memory: " ..fibaro:getValue(SelfId, "ui.labFreeRam.value") .. "\n";
        emailContentMemory = emailContentMemory .. "➜ Maximum free: " ..fibaro:getValue(SelfId, "ui.labMax.value") .. "\n";
        emailContentMemory = emailContentMemory .. "➜ Minimum free: " ..fibaro:getValue(SelfId, "ui.labMini.value") .. "\n";
        emailContentMemory = emailContentMemory .. "➜ Memory Cache: " ..fibaro:getValue(SelfId, "ui.labCache.value") .. "\n";
        emailContentMemory = emailContentMemory .. "➜ Memory Buffers: " ..fibaro:getValue(SelfId, "ui.labBuffers.value") .. "\n";
        emailContentMemory = emailContentMemory .. "➜ Memory Used: " ..fibaro:getValue(SelfId, "ui.labUsed.value") .. "\n";
        emailContentMemory = emailContentMemory .. "➜ Storage: " ..fibaro:getValue(SelfId, "ui.labStorage.value") .. "\n";
    ---    SEND MAIL
        fibaro:call(UserId,"sendEmail", "Weekly Memory Report " .. os.date("%d %b %Y - %H:%M"),emailContentMemory);
    Duplicate. Closing.
