Lacking an instruction manual for the HC2 and window/door sensor.
I opened window after installation of window sensor. It has set off an alarm on my app. To disarm it requires a PIN.
Is there a default PIN? How do I create a PIN?
Yes, there is. It should be 1111.
Edited by jakub.jezek
You can change/create new pin in configeration user settings
    Thank you @jakub.jezek and @Jamie mccrostie
    To create a PIN: Click on Configuration, click on Access Control, click Edit for the User. Enter a PIN and click the obscure looking antiquated disk on the right to save.
