HI,
I have a troublesome FGS222 (v2.2)
It was working fine up to when my HC2 had a meltdown a few weeks ago... and since then it has refused to play ball.
I trued excluding and including, tried resetting it (hold down b button for 3 seconds)
Normally any fibaro relay would include/ecxlude 5 feet away without any button press, this one is needy and seems to only react when it is within 6 inches of the controller.
Should I sweet talk it further with dinner and a nice red or dig a hole in the back garden
advice welcome
-f
I have a similar problem after updating from 4.100 to 4.110 a couple week´s ago. The only way i could get i contact with it again was to remove the power for 15 min and then connected it again and push the button several times. It is still having problems with it, runs for a week or so and then I need to repeat the procedure again.
7 hours ago, AutoFrank said:
HI,
advice welcome
-f
Death by over voltage would be more fitting.
