Hi2Uall!
I configured a (working) Raspberry Pi 3 Raspbian with Node-Red and MQTT (see this excellent YouTube
for explanation). Now on working, and learning (a lot) how to implement this. So far it is very useful to connect several IoT services.
Did anyone have an idea how to connect the HC2 to an MQTT server?
18 answers to this question
" to "
Temat został przeniesiony z "
" do "
Dear,
you can configure a web service in node-red and use these from lua, HC2.
Brgds,
    Thanks for responding Marc.
    I was wondering if it could be done directly from lua, without the need of setting up a (extra) webservice. Or is there a function-block in node red I overlooked?
    mqtt directly from HC2 lua, i'l don't think it's possible. However,  If you can install,
    on HC2 then !?
    on HC2 then !?
    If you do not need support that would be very easy.
    Hmm. But as you know not every user has root access....I do though. Thanks for your suggestion @marc.calis!
    @robmac, do you have a short how to?
    On 4/3/2017 at 3:22 AM, Lambik said:
    Hi2Uall!
    Hi @LambikChecked out that vid, what a great platform. Interested to hear @robmac's reply
    FYI, I just started to explore the node-red/Mqtt platform and realised things, in a short time, what the HC2 will never able to do. Now I'm trying to find a (simple) solution to communicate with the HC2.
    RE hc2 node surely similar to how homebridge plugin is set up?
    I don't know Homebridge.... :oops:
    @Lambik Have a quick read of hombridge posts , i could be miles away here but similar json file exchange between HC2 and pi
    Edited by Jamie mccrostie
    @Lambik
    Q: Now I'm trying to find a (simple) solution to communicate with the HC2?
    A: I made a quick and dirty example with node-red, hope this help?
    Needed: HC2, Node-red, Mosquito (MQTT) broker, change my settings (IP, MQTT broker according to you system)
    How it's working: Sends a deviceID & command from (HC2, browser, ...) to node-red http-server, node-red send & receive MQTT via broker & send result to HC2 (device turnoff)
    Included: (file, node-red flow included, copy, import in node-red)  change parameters for your setup, HC2 IP, Name, Password, (Broker) or use a public broker
    ps: this simple test looks stupid but it work for me, feedback & more idea's welcome
    Thank you Marc, I have something similar right now :-D! Like you way of thinking! :mrgreen:
    But with this solution you have to 'ask' the HC2 what the status is of a device every time. I'm trying to setup a, sort of, a local webhook.
    I'm looking for a solution where the HC2 'talks' to the mqtt-broker, for example, to use in a scene. To be more specific, to use send the content of a global variable on content change.
    good thinking, but confusing for me.
    I presume you would like something like
      or
    or both?
    The normal MQTT binding (use in a scene is easy), the persistence binding is a pain in the ... , i simply don't know how to solve this, maybe someone else has a brilliant idea !?
    Mqtt binding should be enough for the time being. I don't know MQTT very well (just started) and you say it could be easy. What are you thinking about?
    @marc.calis
    @Lambik
    I would also be interested :-D
    My PV panels have data exposed via an MQTT API and I'd like to be able to pull this into my HC2
    I'm right if homebridge is intended for the use of Apple Homekit products?
    Do you have an URL to check?
    IOS SIRI control of HC2 thru Pi search home bridge posts on this forum
