sonypsx 0
i have 4 pieces of Dimmer 2 and i would like to switch them "ON" or dimm them all together with one momentary switch.
I would like to use the 2 wire method in the manual with the single switch (the first diagram listed - and then connect all four Dimmer 2 in parallel to the switch connected between S1<->Sx and Sx bridge to N.
Is that allowed?
I later plan to steer each Dimmer 2 on its own with HABridge.
I must use 4 pieces because of each Dimmer 2 will have about [email protected] load.
Best regards
sonypsx
19 answers to this question
