Setting up Lite Controller
Hi, I am new to the Fibaro world, just got my Home Lite controller with wall plugs and smoke  detectors etc.
The system installed ok, all the actors/sensors are up and running but I am a bit stuck how to configure the controller to do what I want.
The system is installed in a cabin in the mountain and shall be used to keep the cabin warm around 9 degrees C when it is empty and remotely be put to comfort temperature 20 degrees C before we arrive to the cabin.
In addition to this also turn on/off motion and door magnet detector as intrusion alarm.
The plan is to use the temperature sensor in the smoke detector to control the Wall plug to turn off/on heating to keep the cabin to the temperatures 9 or 20 degrees.
I am not sure how to set this up, shall I use Scenes or Events or is it another way to do this?
I would like to have a “handle” in my Android app setting the cabin to empty/9 degrees or warm/20 degrees and another handle to set the alarm off/on.
I would also like to control and adjust the temperature in the cabin when we are there in the Android app.
Anyone who can point me in the right direction?
Hi
I think you need to import VFib again and correct directly there, do not move anything, just change with your own data.
It is your fibaro id you need eg "[email protected]:78-34He" and generate based 64.
In the android app it shows the temperature measured to the left and the temperature in the basic heating panel next to it.
and
In the android app it shows the temperature measured to the left and the temperature in the holiday panel next to it. :)
When I wrote this I had not seen your last post.:):)
Edited by hTiger1
    I think the settings are changing but in the APP it only shows the basic setting i the heating panel, it doesn`t change to holyday setting.
    I would have hoped it would change in the APP so I could see there which setting is active
    7 minutes ago, smarthytte said:
    Jeg tror indstillingerne ændrer men i APP den viser kun den grundindstilling i den varme panelet, gør ikke `t det ændre til helligdag indstilling.
    Jeg havde håbet det ville ændre sig i APP, så jeg kunne se, at der som er aktiv
    Hi
    As you write, I also believe it has been.
    But when I test it right now so changed ranks not from the base heating panel.
    But you can see if it works, by keeping an eye on the temperature and the wall plug.
    Hello and thanks again for the help over the Easter, the VD and heating panel is working fine, I can stay at home watching the temperature in the cabin going in/out at 9 degrees.
    We made it in the end :-)
    I have sent Fibaro a request about developing the app to show the holyday setting and not normal panel.
    They will look into it :-)
    Erling
    Erling
    Hi
    Good to help and good that it works.:)
    Agree with you about holiday setting.:)
    Hi.
    Is it possible to add more sones to this script or do i have to make a VD for each zone? I Would like to putt all my zones in Holiday Mode when i leave and in Normal when i get back - preferably from one VD.
    Ruben
    26 minutes ago, Ruben said:
    Hej.
    Er det muligt at tilføje flere sones til dette script eller skal jeg nødt til at gøre en VD for hver zone? Jeg vil gerne putte alle mine zoner i Holiday tilstand, når jeg forlader, og i normal, når jeg kommer tilbage - fortrinsvis fra én VD.
    Ruben
    Hi
    Have not tried, but I'm very sure you can do it.
    You can also run different VD buttons from a scene.
    Hi.
    Ok - this is my first VD ever so i`m quite blank on how this work. I`ll give it a try.
    Thank`s.
    Ruben
