Sending Email once on global variable change
I understand  the concept of leveraging  a action againt a varaible but how do you send a email in a VD once only on a global vairable change with out it repeating each time the VD loops?
I tried putting a second variable  condition which has to be met for the email to be sent. It changes on "email send" and then gets reset by another stage in VD but it resets every time the main loop runs again
if fibaro:getGlobal("tankEmpty") =="1" and
  fibaro:getGlobal("sendEmailConditon") =="1" then
 fibaro:call(2, "sendEmail", "blar blar blar")
 fibaro:setGlobal("sendEmailCondition","0")
Is this the right approach?
Hi @Jamie mccrostie
My LAN monitor does something similar. It sends one message when s device changes state
You need a second tracking variable and flip its state when the email in sent
In the lan monitor I have both variables in the one global variable in a table but you can use a second global variable
Take a look at the main loop code.
The tracking  variable is called alerttrack and at the table at the top of the code you'll see it there also
Have a look and see if this approach may work ...
-f
Edited by AutoFrank
    Of course I have that installed, why didnt I think to check that.
    My internet is so *abuse* it sends me 20 messages a day :D
    @Jamie mccrostie
    You could use the simple logger for the internet message
    It'll be in lan monitor 3.0 but you could replace the message call in 2.5 to use that instead of sendmsg
    I could send you some code if you like
