Hi. Anyone who has a solution for sauna control. There is a panel connected to the sauna but I think it is better to skip this and use a potentialfree relay and temp sensor. But how to control it? The linked devices thermostat only goes to 28 degrees. Can I in some way use a virtual device. Any help would be appreciated .
6 answers to this question
Hi
A tender could be, controlling it with a Universal binary sensor with Dallas Waterproof temperature sensor 1-Wire DS18B20, heating panel and Virtual Deevice for operation.
Fibaro Wall Plug if it is strong enough, wattage. :)
    Good idea but any tip on the programming of the virtual device for operation?
    Hi
    Have you tried to make a VD before.
    Yes a little bit. But mostly I have found the LUA script on the net and edited to fit my use.
    Hi
    Look at this thread, (ignore post 13, so it will not look like).
    Hi and thanks. This seems to work fine.
