I am having trouble figuring out what real world analog sensors I should be buying that work with the RGBW Controller.  The documentation is vague but clearly shows analog sensors with only 2 leads.  I have concluded that 1-wire and other digital sensors won't work from what I can glean from this site and others.  Every temperature sensor I have seen has had three leads and are clearly digital.  Do I just need a thermister?  Are there analog humidity sensors?
I simply need a waterproof lead to get the temp from a pool.
Thanks for any recommendations.
Use UBS module with 3 wire DS18B20 temp sensor in pocket
Re humidity sensors  let me know if you find one to fit RBG , Ive tried to find one... or search aeotec multi sensor
RBG will still work too, 3 wire +,Gnd, and in. Three wire but UBS cheaper for one input.
Edited by Jamie mccrostie
    Sorry to be daft, but googling "UBS Module" I came up empty.
    Do you mean something like
    I see now that the Fibaro wiring diagram is in fact calling for three leads to vDC, GND, and IN.  I assume Signal needs to be analog voltage connected to IN.
    Thanks again
    Thanks againmodule
    UBS is a Fibaro module check knowledge tab, forum header, manuals,UBS,  more.
    temp will work on window/ door sensor too if you don't want to organize power supply
    Ah sorry, the Universal Binary Sensor.  But that seems to be buying another device to do the same thing.
    I was under the impression from the knowledge tab and manuals that there were analog devices that could directly feed to RGBW controller for temp, humidity, light, etc, etc.  and that I was just being an idiot and not using the right search terms.
    So there aren't compatible analog sensors that work with the RGBW  Controller?
    Well sure you could just use a analog Hot water thermostat with the right scale and connect its contacts  between common and in.
    With UBS I was meaning they are way cheaper than RBG to buy but will work. If you already have RBG
    all good.
    Thanks.  I do have the RGBW Controller and have a number of things I want to measure/manage, so I was hoping to use those inputs without breaking the bank.
    Googling around, it seems what I need is a generic PT100 and a Temperature Sensor Transmitter.
    Or just a DS18B20 3 wire sensor, cheap as chips
    That is what I wanted, but as far as I can tell, it outputs a digital signal the RGBW can't read.  I had understood, I would then need a digital to analog converter to feed to the RGBW Controller.  I'd love to be mistaken.  Does the Controller have a digital input anywhere?
    Sorry about confusion at post I suggested UBS ....
    Yes this will work with RBG
    When you include RBG select correct options set up as input and then for the input the sensor is connected to  "temp sensor".
    It is obvious once you play around with it
    Wow, so you are saying the RBGW Controller will accept digital DS18B20 1-wire style inputs rather than 0-10v analog signal with the right settings?
    Ive used one on pool before, just buy PVC fitting with pocket built in and glue in to filter circuit
    3 wire
    1 signal wire
    It is still  0 to 10v
    I saw this in the manuals and assumed it would not work:
    No, this is a 1-wire digital sensor, compatible only with Universal Binary Sensor and Door/Window Sensor.
    Thanks for posting that.
    May be, the one i used was connected to a UBS but I have both sitting here Somewhere so ill try it.
    Hmm see what you mean. Sorry
    Way cheaper to buy UBS half price of RBG And your pt100 and transmitter$$$
    @askme I guess as you suggested a thermister would do this
    With RBG
    Or a TMP36,  3 wire analog temp sensor @$1.50  via google
    Sorry to barge in but there is no doubt what kind of sensors can be used with RGBW module:
    12/24VDC – power supply signal
    GND – power supply ground signal
    IN1 – potential free / 0-10V input 1
    IN2 – potential free / 0-10V input 2
    IN3 – potential free / 0-10V input 3
    IN4 – potential free / 0-10V input 4
    R – output assigned to IN1
    G – output assigned to IN2
    B – output assigned to IN3
    W – output assigned to IN4
    So what you need to do is search for any sensor that supports output 0-10V and nowadays there are many that support most of the common outputs 4-20mA, 0-5V and 0-10V and all is needed is to setup some DIP switches to select needed type of output. I believe that even sensors with output 0-5V can be used but of course you will have to do scaling of the measured value in the scripts.
    Edited by Sankotronic
    Attachment quota filled up / deleting older stuff sorry :-(
    This can also be used to measure temperature and humidity with an RGBW module.
    The sensors are here 4-20mA and you need to complete with a 500 ohm resistor for the signal to be used.
    The input signal will then be 2-10V which you adjust under Input on the RGMW module.
    1 RGBW module
    1 Transformer 12V
    4 resistors 500 ohm
    2 Temp and Moisture Sensors
    As a sensor, I use the Störk-Tronic FT20
    -20 to +80 degrees and 0-100% RH
    1 RGBW module
    1 Transformer 12V
    4 resistors 500 ohm
    Curious, are the sensors exspensive
    And why the 4 inputs?
    I need humidity sensor solution for either RGB or UBS
    But something not to $$$
