Hi
I can auto create global variables from LUA like this...
function createglobalvar(name, value) -- We create a global variable
  if fibaro:getGlobalValue(name) == nil then
    local HOST = Net.FHttp("127.0.0.1",11111);
    local response ,status, err = HOST:POST('/api/globalVariables','{"name":"'..name..'","value":"'..value..'"}');
      if DEBUG >= 2 then fibaro:debug('Global variable create status: ' .. status .. ' Error code: ' .. err) end
      if SYSLOG == 1 then syslogserver('Global variable create status: ' .. status .. ' Error code: ' .. err) end
    if (tonumber(status) == 201 and tonumber(err)==0) then
      if DEBUG >= 1 then fibaro:debug('Global variable ' .. name .. ' created') end
      if SYSLOG == 1 then syslogserver('Global variable ' .. name .. ' created') end
      if DEBUG >= 3 then fibaro:debug('Response data: ' .. response) end
      if DEBUG >= 3 and SYSLOG == 1 then syslogserver('Response data: ' .. response) end
  else
    if DEBUG >= 1 then fibaro:debug('Global variable: ' .. name .. ' already exist') end
    if SYSLOG == 1 then syslogserver('Global variable: ' .. name .. ' already exist') end
I use that a lot now...
But...
How can I create a VD? I want to be able to create VDs and VD labels from LUA as well... I simply cannot make it work. And the docs s u c k s.
Thanks in advance
Peo
    I simply get...
    DEBUG] 01:14:21: VD create: 400 Error code: 0
    [DEBUG] 01:14:21: respons {"type":"ERROR","reason":"Type not found","message":"Type 'virtual_device'' is not installed in the system."}
    But it seems all virtual devices have type "virtual_device" when listing devices....
    Any clue? Anyone?
    Peo
    It works now...
    The documented API for fibaro states POST to /api/devices to create a device whereas the correct one (found in an old post somewhere) is /api/virtualDevices .
    The working /api/virtualDevices is NOT documented at http://MyHC2/docs or at developer.fibaro.com
    Peo
