Everspring On / Off Switch sends a message: [Power has been applied] several times an hour.
A relay flooded the notification center. A Everspring On / Off Switch sends a message: [Power has been applied] several times an hour. I had to made a scene that deletes the notification center once an hour, because the HCL hanged up from to many messages in the center.
is there some parameter that could be set to stop it?
No... I have created a scene that delete messages twice a day
Also having this issue on a HC3 which runs the latest version.
Any additional suggestions?
Kind regards.
I just installed my new HC3 today, updated to the latest firmware and installed several (5) Everspring AD147-2 in my home. It still generates an 'informational' notification several times per hour so the issue is not fixed.
The notifications pane is flooding with these messages after a single weekend! I have now excluded the devices from polling which is a very undesireable configuration.
@Fibaro: can this be fixed in an update for the HC3?
Edited by I v Wolferen
@m.roszak any news? We are still receiving this annoying notifications... even in HC2
We have forced in template to disable this notification in the device, both on HC2/HCL and in HC3.
This was done some time ago, reconfiguration is required (code was changed in March 2020, version 1.3 of this module).
Device info:
 <productType>0004</productType>
 <productID>0008</productID>
 <zLibraryType>03</zLibraryType>
 <zProtocolVersion>04</zProtocolVersion>
 <zProtocolSubVersion>36</zProtocolSubVersion>
 <applicationVersion>01</applicationVersion>
  <applicationSubVersion>03</applicationSubVersion>
Unfortunately device may not accept request to disable this notification events, if it still happening we can't fix this using Z-Wave protocol commands.
This means that changing this behavior is possible only by ugly hack in Z-Wave engine code itself.
I will request this change but this is something that we just may not want to do - to make sure that we can even try to make it we need templates for all revisions of this product to correctly detect those modules.
The problem is still in HC3 and no news from Fibaro. They should have at least a way to "discard" notification...
Guest jodohl
Sorry, cannot resist this: Experienced Fibaro user should know by now that waiting for promised fixes is like Waiting for Godot. You have to enjoy the waiting even though we all know it will never happen.
Someone in Poland (or Italy) has obviously got the misconception that this will spur us all running to buy a HC3.
Not.
Problem is still not fixed as of December 2021. I have reconciled myself with turning off polling.
Edited by jodohl
Quote
So you need to wait for HC2 update, remember - device re-inclusion (or full reconfiguration) will be needed to apply changes.
Also we can't be sure that device supports disabling notifications, I hope so.
So, 2025 and problem is still here. HeatIt thermostat spamming to HC 2 or HC 3 (several controllers in several houses) "Power has been applied". I don't know what i need to do to stop it. if you have any solutions or scene how to automatically clean up this notifications, please tell me.
